Stop in for a cup of coffee
I know a guy.... I've given you his number...
Yep, I keep forgetting bout him. Been trying to stay local. I’m afraid with my luck, the shipper will lose the damn things on the way back to me
Lawn work, I bought a big JD zero turn for the new place....love it!!
Almost done with the tree work. It will be two weeks, 14 days when I finish...ugh.
All I did today was load the 3/4 ton pickup bed and haul it to the forestry waste dump...back and forth all day, and it was a hot humid day.
That's ok makes the cold beer taste better!!
Storms coming. Tornado warnings a county away. 60,000 feet tops.
North of town 15 min or so. Small but pretty powerful cells.
I may just do that.
Bring the block and heads to him... Have him do the machine work...
He will port the heads and install hardened seats if needed... He will check to make sure the guides are good and put good seals in also... He does great head work....
And if you want, he can build it with you.... He built a couple small blocks with another member here from Michigan.... Walked him through the build....
He can teach you how to build the 440 yourself and make sure it's done right.... He worked at Trenton Engine when the 440's were being built.... He knows alot about them...
That way you will know the engine is done right, and not a hack job like the other guy did to you....
My short block is assembled and everything checked out to with spec of the book. But definitely need to get my heads set up.
I think I’ll try giving him a call tomorrow
