Need to use distilled water. Common issue
^^With coolant that that has corrossion inhibitors in it. ^^
I'd be inclined to. The cavity by the bead is the one I'm most concerned about. Might be difficult to get the hoses to seal.So replace it? ( the housing)
Actually not that bad out today (in relation to the predictions)
I got in about 1:30 PM
Had a delay on the way home.
Drove about 100 feet more than I would have liked. Hopefully the tire's not damaged.
I would replace, but a lot of guys go the Jb weld route and rock em.So replace it? ( the housing)
Well that sucks. You make it home ok?Actually not that bad out today (in relation to the predictions)
Easy peasy. Not bad in the shade. Main thing was not getting hit. Those triangles make me feel much better. They're heavy but work all the time. I rarely carry flares anymore.Ouch.
That's a pain
Sure. Only the second time I had to use that spare since buying the car. Really should replace it. Its a worn out D78-14.Well that sucks. You make it home ok?
Hi Eric, how’s your knee healing?
Should be avaible locallyGoing to see if I can locally source.
I don't care for patches... just means going back and doing it again sooner than later
FIXED.Going to see if I can locally source.
I don't care for patches... just means forgetting about it until it fails at some inopportune time
Glad you're improving. I'm sure when the time is right you'll start to build strength.Still jazzed up. Lots of instabilities when standing or walking much. Wears me out. MRI on Wed. Thanks Pete!
Only if I could hit a tee shot straight and long off the tee, could I score better. Sadly now, haven't hit a golf ball in 4 years....Cheryl and I made eggs and pancakes this morning. We then went to the club and played our third 18 holes in three years. I shot another 78 and she had an 85. We then went and hit the pool for an hour to cool down. What a great day!!
Google can be your friend.....Nope...
At least not at Advance/ Carquest, Autozone or O'Reilly
Google can be your friend.....![]()
Yeah. I have all the apps and they show it being available for pickup, but then you get there and nadda
What would cause the thermostat housing to pit like this??
Is that for a slant?Nope...
Sorry....I only got Nine's.......4 rally wheels,caps and trim rings showed up on my doorstep. Wonder how they will look on Fargo. Need a set of 14” rubbers…
queue Karl
PrayersActually, no she is not. Stili to weak.
