Stop in for a cup of coffee
They are good easily up to 500HP if it has a posi. I stole a Dana 35 for mine out of a jeep.
All I know is it has 3:55 gears, which I like. Don't know if I have to pull the cover or if I can just spin one tire, hold other to figure that out
Yes, Sir!! He came over at 1620, and I was done by 1815. He was great. He showed me the first set of valves, and I did all the others. He also showed me a couple of different options for hooking up the bump starter. With the headers so tight, we had no access to the starter wires. Now I know how to do it, and I understand the valve's opening and closing positions for adjustment.
Awesome... will go better next time.. luckily you will probably not need to do it much at all
One wheel spin is a open rear. yes get it where the drive shaft will turn, rotate the tire 360 and count how many times the DS turns. Cheap upgrade if you want to do it is pull a 355 Guts (posi!) from a Cherokee or jeep with a Dana 35 (same cover) and install it goes right in. Only issue is if you ever go to change gears the jeep had ten bolt holes on the ring gear, mopar 12 or vice versa been a while. Got mine and the disk brakes for 100 when I did it. Prob 50 for the guts.
when i get sick of the 4.30s i don't know what i'll go to.. prolly 3.55 but even thinking 3.23.. if i'm going to give up fun i might as well go in full granny mode
One wheel spin is a open rear. yes get it where the drive shaft will turn, rotate the tire 360 and count how many times the DS turns. Cheap upgrade if you want to do it is pull a 355 Guts from a Cherokee or jeep with a Dana 35 (same cover) and install it goes right in. Only issue is if you ever go to change gears the jeep had ten bolt holes on the ring gear, mopar 12 or vice versa been a while. Got mine and the disk brakes for 100 when I did it. Prob 50 for the guts.
Seller told me rear end came out of truck, don't remember if Dakota or ?
1928 moon!
I bought a Thor and Fantistic Four comic book . Spent $2.00
Dropped off the Valiant Radio to be Modernized. $200.00 deposit. Get it back in 11 months.
