Stop in for a cup of coffee
I had some cash in my Pay Pal so I bought some more NORS chassis parts. 2 tie rod sleeves and 1 outer tie rod end. All TRW.
Step away from the keyboard Mike before you buy more.
I bet not. We’re going with propane for primary. But I’m also purchasing an outdoor stainless steel wood burner that I’ll use to heat my shop but provide backup heat should propane run out or get expensive. Granted I opted for the 1200 gallon propane tank so once a year fill.
Do your research, wood boilers need to run hot to be efficient and for longevity of the boiler. My oipnion is undersize is better than oversize. I toured a manufacturing facility, owner reall knew his stuff.
Yeah. My grandfather used to sell for Hardy
We’re down in Louisville for lunch. Sitting on the river due north of the Airport. They must still be closed cause there’s not a jet in the sky. Normally we see tons of them. It’s one of the reasons we eat here, kids like seeing the jets
While you guys have been sitting at your computers and phones chatting back and forth, I been working so require more booze.
There I talked myself into having a beer for lunch :thumbsup:
I have LP heat but you guys remind me I need to check the shop heater and fire it up. And then watch my money go up the stack
Good afternoon all! Before the snow flies, went out and got the heater in the garage running. Had to make a path to it first, in case I needed to get out quickly. Guess I should go check it to see if it behaving itself.
Been heating my garage for about 2 months so far and wouldn't run the heat past above freezing but I'm restoring another car so it's heat on at 65*..
Ugh! 2 months of heating bills already? I'll leave it at 45 or so. keep stuff from freezing and turn it up if I'm actually going to attempt a project or just move stuff around. have been getting the itch just to dump a bunch of stuff...but I put lotion on and it goes away.
I think next year I'll down size my stuff and just try to keep up with the bills.
