Stop in for a cup of coffee
I have 200 amp with a local co-op. My ex wifes name is on it. They want $300 to take her name off. They shut this service off and start a new one in my name. Why I should care you ask? Well I get a divedend check a couple times a year and her name is on the check. The bank wants her to sign for it as well because her name is on it.
If it doesn't have "AND" between the names, a single signature should be sufficient.
:wtf:
In fact, I received a check from Bedford Rural Electric a couple weeks ago. Not sure how that happened. Haven't been up there for almost 5 years
Auto pen!
You co own the property?
You don't have to answer if you don't want to.
:wtf:
Nope it has the and. I get it done though
Checking in with just 2"
We got a few inches yesterday but the sun melted a lot of it. Getting another round right now. Glad I don't have to work - would have been a sucky drive in. Now, I can spend my free time cleaning up snow later today.
Depending on how big the dividend is, you could pay for that $300 charge in short order.
My house is a third the size of yours.i have 200amp.
Had that added when I put in central air.
That's when I upgraded mine. Oil burner did everything including hot water so it was constantly drinking oil. Did the electric upgrade, then added electric water heater and a few months later heat pump and new efficient oil burner. Had old Federal Pacific box that I understand are a fire waiting to happen...
Also they have a shitload of electric taxi cabs and electric taxi motorbikes. Here in Vietnam. The company is called Xahn SM. Xanh is the word for green in Vietnamese. They're all painted this puke light green color. Very easy to spot. Lynda says don't use them because they often run out of power while you are in the car. Lol
While a have you here. I need new roof
Only one layer. Should I go over it . Or do a tear down?
Twice the voltage and half the amperage. What do your outlets and plugs look like? Similar to the European look I bet.
I suppose they are similar. They have provision for two round plugins and the standard two blade all at the same time. As you know, most of your charging devices now, the part that plugs into the wall is universal for 110 or 220, so I don't have any issues charging anything here
I changed my hot water heater to on demand.
