ScampMike
Despicable Damn Yankee
yea - we can guess and suggest 'til we turn blue - but without being there, that's all it isThat's the PIA with this really need hands on.
I think the fan fills that space inside, so would have to change that. Probably be less air moved then unless new motor has higher RPMI was thinking cut about where the black circle is and add material so the blower motor sits back a bit
yea - I am also figuring on the smaller motor/fan Ray is after - he'll probably have to adjust that fan mount area anyway..I think the fan fills that space inside, so would have to change that. Probably be less air moved then unless new motor has higher RPM
I would have to see it to understand the issue. But why not modify the valve cover? Aluminum, right? Just get someone that can do TIG...Get different Valve covers. A lot of worry and aggravation to make an aftermarket part fit. Isn't that when your problem started? Get the low profile Valve covers.
or thatI would have to see it to understand the issue. But why not modify the valve cover? Aluminum, right? Just get someone that can do TIG...
Have you seen this?If I Dropped the motor the header will definitely hit the pass side. Oh the joys of shoehorning a 440 in a dart! All because of a crappy valve cover also! Do like the look of these much better though.
Not quite. Broke my welder halfway thruhey Chris, you get the 4 link in?
Arg! what you go and do that for?Not quite. Broke my welder halfway thru
Hope your Mom is doing Better !!!Nice, Well enjoy your day! Gotta finish up some laundry then head to the home to hang out with mom for a while. Then its time to get back in the work mode. Had a 4 day weekend, tough to get back into the routine.
thanks, she is. Just not as fast as she (or I) would like. We take it one day at a time, thats all He gives us!Hope your Mom is doing Better !!!
Mine it will not work on totally different animal. Well no go locally think I will just order that one from ebay.
