Stop in for a cup of coffee
I have never seen so much bling on a car before done so well, and the exhaust it is, it is, don't even have a answer, remember it is a real 4 banger. Wheres the crack pipe for the passengers?
So you know how i said I had to fix the wife's flat tire...... well last night, she calls me, the OTHER side now had gone flat, so I went to go change it and I cannot for the life of me get the rim to come off the hub :BangHead::BangHead:
I usually leave one lug nut on loose, Then kick the snot outa the tire and rim.
When that happens in lay on the ground and kick stomp it as hard as I can on one side at a time, enough kicks and persistence gets them loose.
I am assuming it's a newer car? I have had that problem over and over on customer cars
Also , When I have a car on the lift, and wheel is stuck, I just lift it up around head level, and swing a 2ft long 2in pipe on the inside of the tire...
would work if it wasn't in a parking lot lol
I have had had that a lot with aluminum rims just got to beat it to get it to break unfortunately.
I owned a 04 Durango, I did have to kick the tire a few times each time I rotated them. I never had it get stuck that bad though and I never washed that rust bucket, so it had plenty of road grime and salt to help it get stuck on..
