ScampMike
Despicable Damn Yankee
the rears are 305'sThat sounds like a lot for any kind of steering.
Scamper, what tires do you run?
so 12 wide. And what up front?the rears are 305's
So 305/35 front, 355/30 rear with the rear wheel centerline pulled in by 1/2" on each side compared to front. Seems like it would be reasonably well balanced and capable of taking good power through the turn while staying planted.I just talked with Gerst, he recommended no wider than a 12 in wide on the front
not sure off the top of my head but they are probably 26 x 6 or 7so 12 wide. And what up front?
that's the goal, and I should be fairly close, with a full tank of fuel, mathematically, Im guessing I'll be around 50/50 and on an empty tank, 55/45Of course that assumes you have a near 50/50 weight balance.
its all the drag from the chebbie hoodbe sure - my car does not corner well![]()
Jeez, how much fuel are you going to carry? 5% change in weight balance means 350 lbs on a 3500 lb car. 350 lbs of fuel is 58 gallonsthat's the goal, and I should be fairly close, with a full tank of fuel, mathematically, Im guessing I'll be around 50/50 and on an empty tank, 55/45
Why would you have a tire on top of your head? That's just silly.not sure off the top of my head but they are probably 26 x 6 or 7
maybe - but that's also why you'll never catch it in a straight lineits all the drag from the chebbie hood![]()
Wanna betmaybe - but that's also why you'll never catch it in a straight line![]()
Because it can't go in a straight line?maybe - but that's also why you'll never catch it in a straight line![]()
Ok so it'll be less than that lol, 25 gal fuel cellJeez, how much fuel are you going to carry? 5% change in weight balance means 350 lbs on a 3500 lb car. 350 lbs of fuel is 58 gallons
It appears the refs agree. lolOh come on that's a catch, towel boy can't knock the ball out
hell yea - I doubt we'll ever make it happen, but the car is good for under 7 sec in the 1/8th.. so...Wanna bet
eh? you lost me... that's all the dang thing does..Because it can't go in a straight line?
What's your actual 1/4 mile ET and MPH with your current configuration?hell yea - I doubt we'll ever make it happen, but the car is good for under 7 sec in the 1/8th.. so...
1/8 mile times are junior league numbers and don't translate to the big-boy track of the full 1/4 mile...![]()
