Stop in for a cup of coffee
George!
Ok so it'll be less than that lol, 25 gal fuel cell
That's still a lot of fuel to carry...but it won't change the weight balance by more than 2% from full to empty. You should set 50/50 balance as 1/2 fuel load to get the most consistent performance. Also use a compartmented and baffled cell to keep the sudden weight transfer of the fuel sloshing from wrecking the hard cornering behavior.
Twin 12 gallon cells side by side with a leveling tube and valve work best with inertial rotating fuel pick ups so that you never fuel starve in a corner.
I've gotta run an SCCA approved cell, they require those very things for the class I'll be in
And I'm expecting like 5 mpg so for cruising, I'll need fuel
What's your actual 1/4 mile ET and MPH with your current configuration?
1/8 mile times are junior league numbers and don't translate to the big-boy track of the full 1/4 mile... :poke:
It'll be like 5 yrs and by then mikey will have worn out his engine and mine will be fresh lol
