Stop in for a cup of coffee
Rani, did you see my post about the guy from Va that came and got a tire machine yesterday?
Hi Rani, What's on your agenda today ?
make a final decision in the next couple hours on what color of duster I want and then go order the paint today.
its either White with a black longitude stripe and black steel wheels with dog dishes
OR
B1 powder blue with a white longitude stripe and rally wheels.
OR
Decisions, decisions !!
Hey I have to change my oil pressure switch today on the slant, baaad leak. Hope the part is in
That's a very common part. Shouldn't be any problems. Usually when they're near the oil filter they get broken with one wrong pull on the oil filter wrench. Jeeps are common for this also.
ok, fellers I am out
time to make like a fetus and head on out and go get busy before I fall asleep again :???:
Common part but out of stock yesterday... I had to put 2 quarts of oil in last week and thought the main rear seal was gone... I had visions of pulling the motor, but blessed one more time.... thanks big guy in the sky
i timed and raced myself on engine removal ....my slant will come out in 25-8 minutes as engine and trans.
it has no a/c and no power steering and manual trans.
I spray the exhaust studs with canned oil and start draining radiator then get under and remove the driveshaft and plug trans.....speedo cable....Z-bar .....crossmember bolts and I leave two screw drivers to hold the crossmember up after the shifter is off. Then motor mount nuts.
then back on top.....wiring off the engine ...fuel line ...then fan and by then the radiator is drained and ready to come out....then knock out the two exhaust nuts and then the throttle cable.
Then I hook up the hoist and pull the screwdrivers on the crossmember out and finish removing the crossmember and lift engine and trans out as an assembly
Morning Kazoom...Looks good here rain coming the afternoon.
Rani is that 28 minutes? or 258 minutes?
OR
B1 with a black stripe and Magnums (or Keystones) looks sharp. Here's a couple old Challenger of mine.
