Stop in for a cup of coffee
Wow 30 series. I figure about 3 1/2" between the tread and the rim. Can you say Low Pro!
... No no, Not the tire size, I was liking on the tread and tire co. , I will need a215 / 70 in a 15" I think :) You now better :wtf: me running tires like that :rofl:
That's what I have , but in a 14 (Uniroyal Tiger Paw). Even 15's, you will be limited offerings as the new cars are going to all bigger diameter wheels.
Yeh, helps to have a good one of those. I actually have a FABO member local that mounted one tire to let me try it before I bought 4. :thumbsup:
I found a used tire to mount before I ordered the rears for my 66. That worked!
Your measuring that in the lip where the tire sits? Either way, a 215-70 is fine . I am at min width using 5.5" steelies.
inside , I have my eye's on a pair of 6 1/2 wide 15" Stares that match these I have up front
The fit looks perfect, I bet you don't have a clue on back space?
So on the inside of those wheel read 7X15 Mike ? all I can find around here are the small 5 1/2 X15
The 15x7"s on the 66 are aftermarket Rallye wheels. Small bolt pattern with a 4" back space.
