Stop in for a cup of coffee
Dang... And I was just headed there to open a Barbershop....
hahaha you would make a killing..... or at least be stocked in whatever items you can barter for.
Sad world they're in right now.
Anyway, mikey, did you ever solve your brake booster issue?
pretty much leaning toward a 7" dual diaphragm booster unit... of course going to a smaller booster requires changing out my M/C too...
still trying decide what route to go... the problem with the hydroboost is I would have to add the power steering reservoir - which would be some kinda PITA
i struggled with that myself. hang on a second, i'll find the link I saved with the tiny powersteering pump with built in reservoir, its electric powered so it can be mounted anywhere, i'll be mounting it where the battery tray normal is.
Morning all
morning
grrr, I can't seem to find that bookmarked link. I'll keep looking
Your going to have to look at the load thay pump and fans etc draw, I had to go to a 90 amp alt, my load was over 65 when everything was on.
yeah, im going with a 140 amp alternator and dual batteries, i should be ok
