Stop in for a cup of coffee
Made it back easy trip to get the sheetrock in and out in under five minutes! Now to pull the ceiling down...........
Question: I have 4 mounted new tires/wheels right now and I am afraid to stack them 4 high because I figure the weight will mess up the sidewalls of the bottom one. How long can they be left this way?
As long as they are inflated to proper psi, then you should be able to store them stacked for at least a year without issue. Just make sure you put the bottom tire on something to protect it from the concrete like what I used. If they are outdoors, you want to raise them up off the ground on something like blocks and put a good weather proof cover on the stack with a top board under the cover to keep rain water from pooling in the middle.
