Stop in for a cup of coffee
Good morning!
It warmed up.2 degrees!
Yay! Not really.
Will go make a fire in shop, just for the sake of keeping it warm.
Dont think i need to eat for the next couple days....
Fire in the shop sounds good, I have a small stove in the shop and a 100K space heater might just do it.
I have to go to Sherman Williams and see if they make that hammer paint in a silver. If they have it I might spray that frame again if I can get the shop to 60 or so.
BBBBrrrrrrr Ggggggrrrrrrr
What are you going to use Mike?
My sons friend is going to put a heat pump system in, 3 ton he pulled from a school that did a remodel on a work shop, it is only 3 years old, my son is trading it out for a 9" flooter for his stock car.
I insulated the heck out of my shop, when I built it. I even used insulated rolling steel doors. I have R30 in the ceiling, between the shop, and the apartment above. Each floor has its own heat pump with LPG gas backup. Nice thing is... I leave the shop at 50 when I leave. When I come in and set the thermo up to, say 65, the gas heat comes on to get it up to temp. When it gets within a few degrees, the heat pump takes over. So basically , my shop heats up pretty quickly. Usually about 10 mins, and its comfortable. Glad I put all the work and money in it on the front end, of the construction.
