Power takes a bit to get used to in a car that you are used to driving with manual brakes. I put them on mine and really like them, but it has only been up and down the block so far, hopefully June on the road.
:color: sounds great :cheers: congratulations Ben :color:Swapped all the goodies from a 73 Swinger. Replaced eveything that moves, used offset UCA bushings and added reinforcing plate to the LCA. Not sure how I'll like power discs. I'll run it a while and decide. Now I just need to get her to the alignment shop.
Looks perfect Ben, she will stop a bunch better now I bet, I am going with 76 calipers single big piston aswell , Looks like thats what you have
Well Gents I need to run. Have a good one!
Correct. It was really very easy, simple bolt on stuff.. Even the UBJ's weren't that much of a PITA. I do have one caliper bleeder leaking. Gonna try a new bleeder screw first, if that don't stop it, I'll replace the caliper. Kinda sucks since I was all proud of myself for rebuiliding the calipers.. Murphy's law I suppose...
Yikes! Hope he's ok.
He is Ben , Just got an update and he cut his palm at the thumb area on his left hand with a razor knife :glasses7: Been there dun that before, he said he is going to Finnish his day value painting new cabinets![]()
I was having problems with the power button and it finally went. A lot of stuff I would like to get out of it. Maybe one day.
No power at all. I just need to pull the drive and give it to the kid to do surgery on.
Thank you, I desighed it myself after seeing a metal square one on utube for $140.00 ... This things works great and lasts a good while 3 1/2 hours of slow cooking :color: I can't wait to stock up on some hickory and oak and smoke me some stacked ribs :color:
You remember seeing it last night don't yeaThank you pard :color:
No power to your computer but I'll bet the hard drive still works. You can piul it out and plug it into the jumper cable to retrieve your files. My motherboard went out and the computer didn't work but the hard drive still worked. I got all my files back. If your hard drive does not operate it can be taken apart and the discs can be read on another machine (like a DVD player) to retrieve the files. Very expensive if you have to pay for it. tmm
