Stop in for a cup of coffee
Good morning Keith. Whats gunkulating?
Figuring out a little piping project. Need to re- run a cooling circuit/manifold with 1-1/4 galvanized to a mixing tank. Has an internal heat transfer jacket that we pump cold water through. Its been in service for awhile, but piping is kinda ugly and not routed very nice. Just workin out better set-up.
GOOD MORNING. Getting ready to leave for S. Burlington VT. I have to get load on 9/23 in AM for KEARNY AZ.VACATION IS OVER
Yeah its running good though, still need to put miles on it. I cannot find the innards of the kickdown cable. The TT has me dartstracted lately now that it is fall!
Good morning all. I had just enough coffee and just enough filtered water for a few cups. Whew!
It's a good thing that you didn't have to use unfiltered water.... :glasses7:
I knew someone would mention that. We have a pitcher of water in the frig for drinking. After tap water sets for a day the chlorine evaporates out and it tasts better. We have good water here but it is treated.
Yeah there's rubber left, just two dirt ruts all over his yard.... #-o
(Doing the burnouts in dirt saves the rubber on the tires....) :burnout:
Hey it helps with drainage! And it only digs on one side right now. If I can only find the studded snow tire!:glasses7:
I have a 1 gallon Brita container that I use...
The kid and I are starting to degree our cams to see what we have and be able to pick the best one for our applications.
We are on #2 so far, but have about 24 more to go.... :burnout:
I did the first one going every .010" lift, but too much data and it will take too long to do all of the others, so I'm trying to do .001", .010", .050", and every .050" lift until it' maxes out...
I have a tree service coming this afternoon to remove two trees that the "neighbor" is complaining about...
I will turn in a complaint about the one dead one in his yard that is close to the power lines and may take them out if it falls...
Paybacks...
Paybacks...
Karma is a *****! I have a Locust tree in the neighbor's back yard opposite my driveway. Millions of locusts humming in August. Good thing it's too hot out to enjoy our patio. lol Millions of inch long leaves plugging up the gutters and getting in the cowl vents of the cars. Karma took over and the tree is split and dying a slow death. Sooner or later it will have to be taken down. Sooner I hope. lol
