Copper plated steel. You have a welding helmet right?
Duh. Look at the picture above ...Copper plated steel. You have a welding helmet right?
Really? I thought short sleeves, short pants, thin assembly gloves and Birkenstocks was the thang.Oh yeah gloves, long sleeves long pants and sandals!
The steam usually scares the noobs.Come on plug it in when it is wet it will heat up and dry off!
Morning folks. Why would you need a hot water heater?
I feel the same way, Ben! At least during the warm months, I could easily adapt to cold showers. But since this place where I live isn't mine, I need to let the owner know.
Self
It's how they worded it, Water heater would be proper
Hot water is already hot Good day David, when I seen you needed a hot water heater looked at becouse it's not working right, I thought to myselfSelf
Why do I need a hot water heater ! Hot water is hot already, I need a cold water heater
You are too kind. It's surrealism at its best.I se art in your welding Anders![]()
I once had a dream that I was sitting at a table drinking whisky. And I woke up and I was sitting at a table drinking whisky.. Kinda freaky...Guy came out and replaced the bad element in the water heater, all good now.
Nap time now. I woke up in an anxious state this morning from a bad dream where I was the lead actor in a play, opening night, the crowd was arriving and the director was mingling, all the other actors were prepared but I didn't know my part at all.
I knew my day could only get better after that!
I dream that all the time. It's awful.Guy came out and replaced the bad element in the water heater, all good now.
- Welding helmet
- Slag pick
- Welding rods 2 and 2.5 mm
- Heavier earthing clamp
- Set of 35 mm2 (AWG 2) jumper cables to replace the flimsy cables coming out of the welder (that are probably 10 mm2 (AWG 7))
- Air grinder kit
- HSS grinder bits (I'm thinking port matching the intake and heads, what could possibly go wrong ...)
- Propane torch
- Cutting fluid
- Blasting nozzle and hose for bucket suck-up
- Dial gauge with magnetic foot
- pack of gloves.
