Stop in for a cup of coffee
Well, I'm really wanting a custom ground one. Rusty Rat Rod and a few others swear by Oregon Cam Grinders. So I called them, they will custom grind me a cam to my combo for 75 bucks, but want a core cam turned in, otherwise it turns to 150. So I was thinking of turning in that 35 dollar one as the core
ah ha - now that you clarify - get 'er done!
But the rest of the gear is little more pricey!!
yeah exactly. about 400 for their roller lifters. question is, is it worth the cost for my build, I'm already dumping probably 3 grand into the heads/rockers
did you go stock specs or did you bump it up a little here and there?
All I did was clean it up, paint and new gaskets.. double roller timing set, new oil pump... motor only had 60Kish on it and ran nice.. Biggest beef was rusty crap in the cooling passages.. Cleaned all that out..
my first 318 - 72 Scamp, headers, dual exhaust, intake, 4bbl., and an 8 3/4 w/3.23's - - slightly bigger tires on the back... not a hot rod by any means, but it agile and quick
