Stop in for a cup of coffee
The grid defrost might need more amps than blower though. Direct resistance like that can really draw a lot.
I wonder if they ran that back the other side. Otherwise, why would the grid relay be over by the glove box?
Yep, hope to see the Steelers can some tuna shortly. Think I will go downstairs and clean up my tools from repairing the washer and start a fire till then.
I can't believe I'm saying this but I'm rooting for the Steelers this post season
I've learned a very valuable lesson from my canning this year. Take the rings off the kids once sealed, otherwise they rust on and are damn near impossible to get off
We don't do a lot, but never had a problem. Then usually they are in a kitchen cabinet. I assume if you are doing a lot, maybe basement shelves?
I did a bunch but they're stored in the kitchen pantry
At least you have heat:BangHead:
Yup, 1st thing I thought about when I built the place. Put an exposed spiral steel hanging duct in. Used a LPG back up Heat Pump, with A/c. Works great.. I turn the thermo down to 50 when I leave. When I come in,and turn up the thermo, the LPG gas runs until it gets within 3 deg of the stat, then the Heat Pump keeps it at temp. Rarely use the A/C in the summer. Used it maybe 6 times in 16 yrs. The corner of my building is below grade, and a lot of it is shaded by trees...
Wonder why they rusted? I've seen rust spots, but nothing bad
They only rusted slightly underneath where they contacted the jar, my guess is I either didn't get them dried off all the way or wiped down good enough before putting the rings on
