Stop in for a cup of coffee
does the lift have mechanical stop. Wouldn't trust it to park under if not.
Most do now-adays that said, I'd still cut the breaker off to make sure no one can bump the lift controls. we installed an On/Off switch inline on ours and I make sure to set the stops and lock them in place
Yup it is locked. Works well actually.
Here are some pics of the wiring kind of hard to see.
I turn the breaker off since it kills the led strip light transformer also so no phantom power loss.
In the switch I believe. Tell you the truth you just use it on high. There is a wire assy that goes to the switch power in ( I think a bullet connector to under the dash by the fuse block) then two wires and one out, google it you will find it.
OK, cause it needs two wires from switch to resistor. Then one from there to the motor. Motor is body ground for sure. Looking at FSM just adds confusion. I see wiring for blower and text in bothe chassis and body books references heated grid window with relay mounted behind the glovebox. :BangHead:
I just winged it after I found a switch and the wiring at Klingers. Seems like the bezzle for the switch is a bit rare also.
If you need I can take pics one day, let me look for the motor assy, I can make the wiring up I should have all the connectors and terminals.
No biggie. No rush. If I decide to persue it I can look at it sometime when I am there. Maybe run the wire when I have seats out -if I ever get around to upholstery...
Yep, hope to see the Steelers can some tuna shortly. Think I will go downstairs and clean up my tools from repairing the washer and start a fire till then.
Not worried about the Fisheads... I'm hoping , they beat DALLAS next week...
None there I got them all, most are sold.
I seriously wonder if the wire is there already?
I really do not see them making different tail light harneses just for that. Prob the same wire for the defroster I would think. My fsm is in the shop.
My 68 has a trunk light... I wonder if they would use that wire for defrost, if it didn't have the light.
I think they are wrapped together going up there. Have to look been years since that went in.
