Stop in for a cup of coffee
Try drawing circles then...:lol:
believe it or not, i just tried that and couldnt figure it out lol. We use photoshop at work but it's only in black/white and for minor editing.
well... it appears i dont have the correct type of photoshop......
If not AC, I would bet its emissions related. That side of the harness would have (or not) as many as 3 'black box' items. one was an EGR delay timer. Off hand, I cant think what the others were.
Prb also a seat belt interlock reset plug ant the choke timer, mine had these all and got rid of them with the new harness.
Whats really funny the diagram closest to my wiring is from a aspen (thanks DDaddy)
Definitely got versed on 74 wiring for sure, the dash is the same extra plugs. I put a rear defogger in and the plug was there under the dash!
They are around, usually around 100 for it all driver quality and of course no duct tube like all of them. Looted klingers for them. There is a a body and then the rest. The one I used the speaker can still be mounted in it. Have to show a pic think it is a b body one since I had to mod it to fit.
NICE! I need to go to this yard lol
Only thing I do not care for it is a three postioni switch high, off, low It is quiet and you can leave it on easy since it is next to the map light switch. It works, bareley takes the inside air and blows it on the center of the rear window,
Keefer I still might have one of the motors and plate, you will lose a 6x9 though and still need the center moulding and duct.
I had one for a B Body with the escutcheon and the duct tube. This one mounted in place of one speaker...Think I sold it in Carlisle.
It seems to work ok for condensation, Used it once so far. Just a cool old man option! Hey it added two lbs behind the axel!:lol:
Know what was a pia to find a grill that worked with it like a screen so crap does not fall in it. Oem ones were big$$$
Man I am still freezing from yesterday. Hey don't you love universal parts? That new antenna was a pia to make fit, splice the old plug on, splice the female end of the antenna wire on, modify a drain tube, the worst part was taking the spare out! What a *** pain, the instructions are under the panel for the top when it is down that has to be removed! That took 45 mins!:mob:
My package tray had the vented cut out made into it.. They also served to hide the speakers. If you had rear defrost, you only had one rear speaker.. W/O defrost, you could have two.. This is on 68 B Body..
