Stop in for a cup of coffee
when you get all set going to loom/wrap them up a bit?
Only the horn wiring that goes across the front radiator support... I found some spots where the insulation wore through to the wire and it shorted... Will put convoluted tube around that one... The rest I plan to leave just taped, or whatever the kid decides to do with it - it's his car...
Well, I gotta get ready for work now...
Will have to do the parts running after work...
Smell you all later...
Any one need hinge bushings got a bunch again. Wonder if there is a marked reconditioning them? Not hard to do at all.
gotcha
Ray.. I do need some for my Ram..Lemme know how much..and shipping...
Gotta go run dem E-rands now...See Yalzz...
door hinges? just curious, I got kits for mine and had to do a little extra clearance to go back together. Wondering if i got BS bushings. Not a whole lotta room for the bushing flange.
I was totally expecting a team of internal auditors to show up here this morning and go through our stuff with their fine toothed combs. 9:15AM and no show.. could be a good day to go screw around in the shop!!
you know as soon as you start the auditors will show up
Their MO is to show up first thing on a Tuesday AM. Get in the way all day Tuesday and Wednesday, do a wrap up Thursday AM and fly out. I figure if they ain't here by now, It'll be a few more weeks before they show up...
Probably on the Duster. Never had the doors off. They close OK, but there is some play. I assume that would tighten them up. Never did any...
Never saw any good deals on them other times I looked. I seen @halifaxhops was getting his and checked ebag. $9.88 incl shipping! Be nice to have the right year after nearly completing my car with a 74 manual. I also just bought the body manual for about $13. Good thing since the first thing I looked for was the electrical drawings. Seems they moved to the body manual in 75...
Yo Ray,
Don't know if you saw I posted this yesterday...
I just hit them fast with a BFH to bend them a touch then drill them, works well. That flange does interfere for sure rather not take metal away from it. Wonder if I can find a bit to counter drill the flange just a bit.
yeah, not a whole lot of meat there. I buzzed them a touch with a clean up disk.
