ScampMike
Despicable Damn Yankee
well - switching that booster sideways is going to be fun... first try pushed it too far to the left and it hit the rollbar front frame brace... doh
- didn't see that coming. Second try got it in closer but still too far left - well
. So it seems the best I can do (if I do keep my current booster) is to redrill the original brackets to move it all 1/2" left - the problem with that is that where the holes need to be doesn't allow enough room to turn the nuts - ah nuts this is
!! SO, because the car is disc/disc it appears I do need the larger booster (right??), I am going to buy an aftermarket bracket set and make modifications to that - this way if it doesn't work I will still have the unmodified original pieces that I can go back to.
Oh Chris @dukeboy_318 - cool stuff with the Hydroboost and all - but ya gots ta have power steering...
- - which I do not.
!! SO, because the car is disc/disc it appears I do need the larger booster (right??), I am going to buy an aftermarket bracket set and make modifications to that - this way if it doesn't work I will still have the unmodified original pieces that I can go back to. Oh Chris @dukeboy_318 - cool stuff with the Hydroboost and all - but ya gots ta have power steering...
- - which I do not.
suckma
