Stop in for a cup of coffee
This is actually false. When a weld is done correctly, it will be structurally stronger than the metal welded on. Essentially you're not only heat treating that metal, but adding alloys to it, thus increasing its sheer strength. Where welds run into problem is if the person welding them doesn't insure against contamination or pores in the welds.
I may have used the wrong word, but I meant durability in the sense of ability to withstand cycles of changing stress. Introducing a discontinuity is detrimental in many cases. Even if the weld itself is strong, the fact that it is stronger - and stiffer - than the surrounding material can result in fatigue around the weld because the stress increases in the surrounding material when the weld doesn't flex.
You said it yourself, a one-piece part is stronger than a welded part. It isn't because the weld is weaker but because the weld and the surrounding material isn't equally strong.
But I didn't major in material science och mechanical design but in electronics so I could be entirely wrong. :)
They aren't. When I get to work tomorrow, I'll upload the CAD mock up I did of them when I was trying to design my own suspension around them. Which is why I called Ron to begin with. Was having issues getting the Ackerman right and that's when I learned it just isn't possible when flipping them. The 3D scan shows all the angles. I think the chassis manual has them too but I don't recall, these angles and dimensions for my drawing were done with our lasers. They're accurate to within 5 decimal places .
The spindles are slanted backwards, aren't they? That would screw Dave's drawing.
No thanks. If you need pain Meds. It's best to not wait till the pain gets that bad. Keep it built up in your system. After breaking my arm in nov. And again late Dec. Along with the shoulder I understand not wanting to take pain Meds. I was surprised that Asprin and tylonel worked best for me, and that was only the first few days.
I had some morphine-like pills when I had my shoulder surgery a few years back. It scared me taking them. I was certain I would become addicted so I quit after like two days.
WTF are you doin up Ray....Anders....I understand you...Probably, what 9am there ?
Crazy night, I crashed about 4 for a nap before the storms got here, got up at 5:30 and had supper, then hung on as the storms got here , Buddy was going nuts and Treva fell asleep, I crashed again at 8pm , to much sleep
