Stop in for a cup of coffee
Here it is Hoppy.
I need some of the plastic shaft retainers on the b/rb dizzies have a few that need them no idea where to find them, any ideas? Holds the drive shaft in the case on the bottom of the housing.
Morning guys. I couldn't find those last summer when I needed one. I ended up using bushing stock. It was the correct size without modification.
Tike that is definatly a stripper there.
TMM that is prob what I will have to do, was that just a standard bushing stock? I did not measure them yet.
It is so rusty....I may lose my money on this one. But it does have some things I need.
Yep. Just standard stock. I got a piece from a welding/machine shop on my route.
The hole in the dutch panel was so big I put my arm down through it to see it the stainless trim corner piece fell into the trunk
Hope it has a title! Might ask you to leave it on the trailer till Keefers car gets painted then it can go into the side bay the belve was in.
Hey, oldies!
Took the deep fryer out for lunch today, my son wanted chicken nuggets so I made that and fries. Easy cooking but a PIA to clear away.
We always run the oil thru a coffee filter after using it. Stays ok for ever!
