Nice Anders I just have to measure it with metric to see what size they are. Funny the year ones are not the same shape or even near the oem, I will get a pic when I get back fron the PO.
I looked though the newark list, Ray. Nothing for you there, I'm afraid.Nice Anders I just have to measure it with metric to see what size they are. Funny the year ones are not the same shape or even near the oem, I will get a pic when I get back fron the PO.
I got a set from him, did not fit and he has none that will. made want ad..Fingers crossedor just ask whitepunk
so obviously the vert pieces are different -- yikesI got a set from him, did not fit and he has none that will. made want ad..Fingers crossed
well wait - what's the problem - - ya got one right there!!
Or cut in the middle and press sleeve onto the rod? I have a 40 ton press that should crimp the **** out of it......So in you guys opinion, to shorten a set, cut near the middle and weld in sleeve, or cut at end and heat up to make one bend?
Get a sleeve that is a perfect tight fit, or drill out a sleeve to the right size? I have to do something....Or cut in the middle and press sleeve onto the rod? I have a 40 ton press that should crimp the **** out of it......
Yep, same as welding it....isn't that spring steel though? once you've cut it you compromise the strength
Then crimp with the pressGet a sleeve that is a perfect tight fit, or drill out a sleeve to the right size? I have to do something....
maybe epoxy the connection then while setting crimp it?I would ask a welder - the 40 ton press thing sounds promising
I would expect that getting the bends exactly right with that steel to be pretty challengingOn the cut and bend deal, I can cool it off fast dunking in water, might retain some of it strength, might....
No Factory size trunk rods.is your car mini tubbed?
I do - who knew!!? Are you looking to go stock look or would something aftermarket work - like struts?No Factory size trunk rods.
see how the hinges are moved in?
I put struts in my 66, so I know how to do it, But I would like to see if I can make torsion rods work.I do - who knew!!? Are you looking to go stock look or would something aftermarket work - like struts?
yea - I got ya.. and I get itI put struts in my 66, so I know how to do it, But I would like to see if I can make torsion rods work.
