Stop in for a cup of coffee
Prob your best bet AutoZone and Pep boys suck for fittings, advance is a bit better but not much.
If you find one make sure it has the flare recess, a regular NPT one will leak and ruin the master, trust me been there and I had to get a new master. You have a flare tool?
I had a NPT that fit the M/C rear port and allowed the brake line fitting to thread into it - leaked like a sieve -- which is how I ended up where I am now..
Something like this?
Seriously just find the nut and put it on, if the bend is to tight just change the line to the prop valve, the steel line sections they sell are a ***** to bend I have a roll of the easy bend if you need a length to do it with.
I have a tube bender too - I will make this happen
