Stop in for a cup of coffee
Detonation will only occur if your advance exceeds the available fuel and you are running lean. It's not about what you add so much as when you add it. More advance just needs more fuel so it can use it efficiently across the curve. This is why it's a balance between A/F ratio and ignition timing to get the acceleration curve optimized.
Racing is about WOT, street driving is about all throttle positions, RPMs and engine loads.
What cam are you running and what is the manufacturers recommended advance curve?
With 9:1 compression and 93 octane fuel, the 360 magnum engine can take 50° total advance if the A/F ratio is correct across the timing curve.
Comp XE268H, here is a link to the spec card
20-223-3 - Xtreme Energy™ Hydraulic Flat Tappet Camshafts
Im sure I'll be running thru the campground in my undies chasing raccoons, because they raided our coolers. Seems to be every time I go camping. LOL
I would recommend you wear pants/shorts when chasing the raccoons or someone may get the wrong idea if they see you chasing one in your underwear.... :poke: :wtf:
Raccoons are hard to catch.
You almost need to jump on them when you catch up to them and put your knee into the front shoulders of it and push down and use your left hand to control the head to make sure it don't bite you and your right hand should be free to have your knife and stab it.
It's like a mini rodeo because when you put your weight down on it, it will squirm and fast.....it is not easy but once you do it 5 or more times it gets easier.
A glock makes it real easy
some dude needs to put a ring on this girl's finger and soon! :rofl:
Well, it wasn't my choice to go around killing raccoons, but i have chickens and animals that need protecting and i was on my own
, so what was i supposed to do lol
Its just a case like everything in life and sometimes you just gotta do what you have to.
Got PCV valve in yesterday, found out how much vacuum it pulls. Got it to 7 inches in gear. Might fine tune it a little more.....
Rainbo in action.... :elmer:
We need a demonstration - I'll be the raccoon.... I promise not to squirm too much... :p
(I'll most likely look like a raccoon afterwards...) :rolleyes:
Fitting I made..
Pics??? Video??? :popcorn:
Or it didn't happen.... :poke:
You almost need to jump on them when you catch up to them and put your knee into the front shoulders of it and push down and use your left hand to control the head to make sure she don't bite you before you stab her.
It's like a mini rodeo because when you put your weight down on her, she will squirm and fast.....it is not easy but once you do it 5 or more times it gets easier.
fixed it!! :lol:
Rani Rousey.... (Female MMA fighter reference....) :poke:
