Stop in for a cup of coffee
I welded on sway bar tabs on lower control arms, but in the middle of the tabs, it is a mess, looks poorly.
Woweee !!! Dead in here... Did the Coffee Machine Die ???? Someone call Scampmike and Schmooze him......
Back at it. Had to run some errands and paid Mom a visit.
Yeah... I just got back from a test ride in my Cummins Truck. Had to go to the Beer store.. I had just changed engine oil and filter, fuel filter, transmission mount, adjusted the bands and the shift points and pressure. Added a deep Aluminum Trans pan, And....Changed the rear pinion seal and gear oil.
And she runs like new! You deserve a beer.
You forgot to rotate the tires!:poke::rofl:
Is that all?:lol:
I rebuilt the transmission myself about 5k ago, and had not been back inside of it until now. So , as I said , I adjusted the bands and the line pressure, shift points. Made a pretty big difference, Shifts much firmer, and now with the deeper Alum pan and new fluid, it should be good to go for a while...:thumbsup:
