sadly not the only one eitherYou missed a golden opportunity there...![]()
Drawing a blank thereThat was my baby that I spec’d and oversaw the installation and programming of to do its work. It was designed to move 800 lb pieces of equipment around in a small space and place them accurately within 1 mm of where then needed to be.
It’s name was “Gort”. See if anyone knows the movie reference for where I got it from.
Never bothered to paint one so I'm no helpA question for the brain trust. A few months ago I took the exhaust manifolds off the Barracuda, bead blasted them, cleaned, and painted as per the instructions on the can (Bill Hirsch exhaust manifold paint). I baked them at 350 for a half hour, waited a couple days and put them back on. After several drives I have one small spot that I apparently touched before it was dry, or something like that. The paint flaked off. Other than that everything looks great.
I'm not going to take the manifold off again to repaint it. I think because the paint is only a four months old I can clean the spot and touch it up. Or should I tape it off and repaint the entire manifold?? I still have the same can of paint I used before.
My question, I know I run the manifold temp up to 350 to cure the paint. How many times to you suggest I do that?? I thought a few times running the temp to 350 letting it cool off for a few minutes and repeating. I know you guys will have a suggestion. Thanks in advance.
Gort was the robot from “The Day the Earth Stood Sill”Drawing a blank there
Didn’t we already answer this one and I gave you the link to get an IR gun to measure the manifold temperature?A question for the brain trust. A few months ago I took the exhaust manifolds off the Barracuda, bead blasted them, cleaned, and painted as per the instructions on the can (Bill Hirsch exhaust manifold paint). I baked them at 350 for a half hour, waited a couple days and put them back on. After several drives I have one small spot that I apparently touched before it was dry, or something like that. The paint flaked off. Other than that everything looks great.
Yes you did I know the temp just wasn't sure how many times. Oven was 350 for 30 minutes, wasn't sure on time curing on the engine.Didn’t we already answer this one and I gave you the link to get an IR gun to measure the manifold temperature?
Just clean off the flaking paint, scuff a little beyond that and repaint that spot overlapping the old paint. Cycle the manifold to 350* three times and you are done.A question for the brain trust. A few months ago I took the exhaust manifolds off the Barracuda, bead blasted them, cleaned, and painted as per the instructions on the can (Bill Hirsch exhaust manifold paint). I baked them at 350 for a half hour, waited a couple days and put them back on. After several drives I have one small spot that I apparently touched before it was dry, or something like that. The paint flaked off. Other than that everything looks great.
And nichtmitderfingerpoken...and if that don't work, strip the whole thing down and do the whole thing...
LolAnd nichtmitderfingerpoken...
Like a halogen headlight bulb. I always wear disposable rubber gloves when I handle that stuff, takes the guess work out.And nichtmitderfingerpoken...
Aparrently just a fingerprint will cause a problem...
Trying to get some dinner together myself. I think the recipe I just used was titled "How to flame cook chicken breasts on the grill in less then 4 minutes" Step 1. marinade in Italian dressing..............Cheeseburger. bacon. lettuce. mayo. tomato. onion. jalepeno..
and French Fries.
I don’t believe you. There has to be whiskey in there somewhere...Cheeseburger. bacon. lettuce. mayo. tomato. onion. jalepeno..
and French Fries.
You're right.. That's my plan for lunch tomorrow.. And it's Vodka tonight.. Ran out of bourbon.I don’t believe you. There has to be whiskey in there somewhere...
The world is ending! Run for your lives!Ran out of bourbon.
Yeah, looks like they downgraded it here too...not complaining, but find it amusing... this time yesterday our forecast was 100% chance of 3-5 inches of snow for Saturday. Now, no s word. 10% for any precipitation.![]()
