Ddaddy
Just doing what I do
Two things to do, first swap the radiator cap for a modern one and see what happens. Second, run a compression test.
What's the pressure number ,on the cap ? 5 to 6 ,for no overflow tank ,rough 12 to 16 for overflow tank. 3 degrees of cooling response, for every pound increase . Running too big pressure cap, can damage cooling system parts. What is the temp ,originated poster ?Two things to do, first swap the radiator cap for a modern one and see what happens. Second, run a compression test.
Expatations?damView attachment 1715185159 NO MORE EXPATATIONS!
Expatations? I like expatations!Expatations?
I might too...if I knew what it was!Expatations? I like expatations!
Well, at least it was an easy fix.Got it home. Found the problem. The over flow connection on the overflow itself was clogged, which is a ***** to get to as you have to remove an armor plate
At least it wasn't the head gasket!!Got it home. Found the problem. The over flow connection on the overflow itself was clogged, which is a ***** to get to as you have to remove an armor plate
You can see me? Am I hawt?Ben!! Good to see you back!
You're a sick woman Barb! I like that!Of course.... looking in your window right now!!! hahahhah
You reallyyyyyyyy don't want to know!!!He's got the blinds open again
OMGWhat's he doing to that exhaust manifold?
Depends on when the gasket fully failed. Also, heat expansion can have a big effect.Yeah. Thanks for the tips. Question, if it was the head gasket, wouldn't it had been doing it as the engine was running, not waiting until it warmed up some?
Sunfire/cavalier?I have run a POS car for months (very short trips) with a blown head gasket. Never added coolant to it... go figure.
Toyota ?I have run a POS car for months (very short trips) with a blown head gasket. Never added coolant to it... go figure.
Bingo... give that man a cigar!!!! Cavalier. It still runs lolSunfire/cavalier?
Notorious...
