Stop in for a cup of coffee
Your loss...Our Gain......:lol::poke::poke::poke:
Honest opinions needed. For a cheap, temporary solution for the saggy rear leaf springs, can I use air shocks?
I would not. They place undo stress on the upper shock cross member. I have seen where that destroys those attachment points. You can add a helper spring to them now, until you replace them with new units. Not sure, but I think new springs for that are not that expensive. My 65 Belve had helpers, someone installed. I'll get a pic for you....
thanks! New springs for this aren't bad. just no one has any in stock. The 63/64 B-body had a unique front length. They make adapter brackets to put 65-67 B body super stock springs on but that adds 200 bucks to the already 400 in springs. I just want something that when i put my 30 lb kid on the trunk, the bumper does hit the ground. Keep in mind, the previous owner removed a leaf to lower the car.
From ESPO: Give them a call.
70-74 Barracuda, Challenger (E-body) - $220-$250/pair
63-76 Barracuda, Dart, Duster, Valiant etc. (A-body) $220-$250/pair
66-73 Belvedere, Charger, Satellite, etc. (B-body) $210-$250/pair
66-73 Chrysler, Dodge Full-size $310-$400/pair
Will do!
crap... no 64 B body stuff :(
Find a used set of springs,and add a couple to your stack.
I have added before, its not the greatest solution, but it is the cheapest. I’m cheap so i would know.
I had to add a leaf to my power wagon fronts to carry the plow.
Made a huge differrence.
Time to go wash an engine,crank seal puking oil all over belt and accessories. Easy to change tge seal.
The previous owner did that on my Swinger. It rides like a old buggy. It works, It's cheap but it is not the way to do it. I put new ESPO springs on my 66 Dart 10+ years ago and never looked back.
