Stop in for a cup of coffee
Stand alone
Only pics I have of his car. Currently with a hot little AMC 360
Hmm what's SA mean?
So would one need the shift paddles and column then?
Sa=stand alone. It is a Mopar Performance part. The autostick is part of the console shifter, no paddle shifters required. The SA TCM allows the NAG1 trans to operate either as a normal automatic or be shifted manually, just like it was from the factory. The TCM controls both modes.
So one would have to run a console shifter than from a charger ? Or could one rig up their own shifter some how
All you need are the switches. The police cars have the autostick function on the column.
I would use the console shifter just to make life easier.
So it's creamy, cheesey and sticks to your ribs.
Yep Karl will have a field day with this.
In other news Granddaughter is currently leading the field in 100 meter event. but heat is kicking her butt.
Running ain't easy. Good for her
Got a video, going to try to get it up, the video, you guys and your dirty minds...
uploading now....You tube..
