Stop in for a cup of coffee
Hey March 20th first day of spring. That Groundhog better have it right or TMM might put out a hit.
Just sayin'
MyMopar gives me a 3754118 for Right Rear. But, there description on the 374119 looks like multiple listing including left front - which is definitely wrong. So maybe factory decription was wrong at some point? :wtf: Fronts and backs use same rubber, but are definitely different contour for the metal.
I'm surprised we are still allowed to use the term "white out" when talking about a blizzard! I'm sure there are people that are offended. :rofl:
No doubt. Here's a snow plow cam just west of here Iowa Department of Transportation Traveler Information
That was fun. I know what that highway in Iowa looks like as of 10 minutes ago :D Good morning :D
PG&E had a fun night here. Power went out here at 7 leaving the grid 4 blocks from here on then skipped another 4 blocks and darkened the Airport. Outage then skipped a portion of Santa Maria proper before leaving the north end of town in the dark. Blacked out the little town of Guadalupe out by the beach. Missed a big chunk of more rural ground and darkened Oceano, Grover Beach, and Arroyo Grande. All within 10 minutes of each other. Weird :realcrazy::realcrazy::realcrazy:
So with a snow storm a white out can cause a black out??
Now I think the proper term is "experienced a loss of power" or "power outage"...just saying.
Just about done break time.
Made and killed a batch of SOS and scrambled eggs. Mmmm
Got the Neon all the way in the garage and still have room to get around it to work. :thumbsup:
Pulled the wheel well splash out and facia loose. Took washer bottle out and straightened metal behind it. Next up changing the belts.
I knew the car was hit and suspected a lot of metal was replaced. Judging by clearcoat pealing, I would say facia, hood and maybe both passenger side doors were changed. Then it got hit again at least once. Or, more likely by the repeated same damage, the driver just couldn't keep off the wall. lol
Ugh!
Decided to de-grease the cables on my hoist. A horrible mess.
Im covered in grease smears and
Stink of varsol. Sticky.
End result is cables will be clean and no grit will stick to them.
And i did find one with a couple damaged strands. So i have to look into a new cable.
