Stop in for a cup of coffee
318 poly leaking oil. After all the careful prep and sealant it should not leak. Corner of head and block #2 cyl. Coming out from under intake. Blast off with brake cleaner and compressed air.
Put my air lift on the oil fill hole and applied vacuum while i applied a dab of silicone. Let it sit for a couple hours and it appears to have stopped leaking.
Failing that i have to pull intake again.
Those are prone to warping or even cracking in that area.
Morning.
Got some grass smashed down yesterday evening. Spent a couple hours mowing and trimming. Bought a walk behind trimmer last year, that thing is awesome!
Morning/
This thing works really well, has a auto cylinder balance also built in.
Ray I have the carbuertor!! It looks really nice and has been test run on his slave engine before he shipped it.
The truck is pretty much done just a few odds and ends to do and fix the driver side window not working all of a sudden, have to have that in July here!!! Just a ton of little crap needs to be addressed that I did not get to last year.
