He's got a 318 Poly , Karl....On small blocks, there are symmetrical and non symmetrical bolt patterns... If you have the opposite, you can rotate the pulley until 5 of the holes line up and then egg/oval out the mis-matched hole so the bolt can go in... Make sure to use a washer on the hole that you enlarge to make fit...
