Stop in for a cup of coffee
Also need to figure out the radiator.....
This was an original V8 car with A/c so I think the radiator support was cut out for a 26 inch radiator.
Did they make 26 inch radiators for slant sixes ??
I had a too narrow rad for a dodge truck, i just bolted in flat strips of sheet metal to fit rad. Easy. Not factory but thats fine by me.
33* outside with W wind at 12 mph. It is this at my bench with only 900w of heating.
I’m a happy camper.
One thing about the rear end in this car is it's a BBP 7.25.
I wonder if the BBP factor makes it any tougher than the SBP pattern version?
Talk to a rad shop,see if they are willing to move bungs.
Talked to my welder buddy, said he would move them if i had an aluminum rad.
I would consider moving them myself if it had brass tanks
I need to get a new radiator because the original v8 one was long gone before I got the car.
I don't think I have slanty one
Might be time for a want ad
I did the same thing, 16 gauge sheetmetal drilled the holes, backed up with j nuts and painted to match looks factory
Maybe that you dont want to but bungs are on the same side.
Then add the mounting plates.
so I think this one is a better deal, says 1.032 inch bore and says it's for manual front Disk and rear drums, doesn't specify what size of rear drum.
https://www.oreillyauto.com/detail/...9093/1973/dodge/dart?q=master+cylinder&pos=10
I think the one you are looking for is the aluminum ram 80's one. I believe this is the one wilwood charges over $100 for also.
You may need the 2 to 4 bolt mopar mounting adapter, but this is what I used.
1989 DODGE W100 PICKUP 5.2L 318cid V8 Master Cylinder | RockAuto
Gonna go take a ride with the GF now, so she can have her eyelashes done/lengthened..Very common practice here . Of course facials, massages, and nails are also very important. I will sit next door at the Cafe and drink Coffee and smoke Cigar..:thumbsup:
So,,, As some of you know, I bought my own Motorbike here, bout 5k new. 2017 Yamaha NVX. 125, Upscale bike, has 7k kilometers . Got it for 1500 US. Can cruise at 80 kilometers easy, if needed, but usually much slower here on traffic
So we go out today to run some errands, and I notice the rear tire is very low. I check for foreign objects, and find none. So I tell her we need to go get air, and check the front also. Ok.....She insists we go to the Yamaha Dealer....I'm like WTF ? If I had a pancake compressor and some tools here, I can service it myself.
So we get to the Dealer, and I'm like, just get some air. She's like, no let them service the bike.....WTF ???? OK !!!!!.... Sit on the customer area for 30 mins, and.... They bring you free drinks. I find out they changed the engine oil, aired up the tires, changed the throttle grip, replaced the key fob battery.And washed it. I'm like Ok... Here it comes,,,,bend over... Total bill was 300,000 Viet Dong, $13 dollars US....Nice little Dealership, here are some pics.
