Stop in for a cup of coffee
Morning MOPAR dreamers and Stephen the sailor!!
Warms up to the 30's here, and then 60 by Sunday!!
our forecast
Morning Craig.
good morning Mike and everyone else here
Yes they can why though? Screwdriver or coil wire works fine. Better yet lick it and jump the starter relay! Chris just take 12v and run it to the + side of the coil and see if you get spark. If you do it is a wiring issue, if not ignition side. You can get 12v to the coil but no amps also easily with old wiring. That's what a load light is for.
LOL Tin foil hat is recommended
1 for better ground to hood
2 Absorb the impact if you get spark.
I've tried the coil wire to engine block trick. Do the coils have to energize for a bit ? If so, maybe thats my problem.
yes, the old one showed nothing, new one moved the gauge way to the right but I forget the number off top of my head
Google the specs there is a primary and secondary resistance. I am really thinking wiring. did you jump the new coil with 12VDC and see if it works?
Gee that helps. Need a number and how you hooked it up. Did you buy that digital meter a while ago with the dwell option I posted?
yep, nada. I even bypassed the ballast when i did it. I'm wondering if a bad dizzy wire maybe, thats the one thing I didn't check.
Shoot, I forgot I bought that one. I'll use it tonight. its brand new and in packaging still.
