I think it would be pissing out fluid if that was the case?How far inside of the tailshaft is the bushing? The yoke needs to be inside the bushing and not just ride on the splines.
Any chance you have access to a lift? Put it on jack up the rear and run it and look at the drive train if possible.
I do....but ...I can just get it up on stands and watch it...Any chance you have access to a lift? Put it on jack up the rear and run it and look at the drive train if possible.
That might be your answer. There will be some fluid that leaks past the bushing and around the splines but the seal should keep it under control. A loose tailshaft could damage a seal pretty quick though. Can you see any marks in the yoke where a seal rode in the past? If you can, it isn't in the tailhousing far enough I would think.It is leaking some fluid from tail shaft...another reason I point towards driveshaft length. I have another tailshaft in the garage...I will measure how far in the bushing is, then measure my yoke...I'm banking on this being the problem...
Good morning everyone!!! So I have seen this question asked but I dont know if I have ever really saw an answer so I'm going to ask. What is the driveshaft length for a Duster with a 727 and 8.75 rearend. I had one cut down here a while back for my son's car but, I think (judging from the vibration) it's too short. I just measured the one that was in the car when I had the one cut down but, not sure what it came out of..
See if the lower shaft has up and down play.
I haven't given much thought to tilling my little garden yet. Unless I do any early stuff it can go a month yet. Might be getting rid of the hops. Maybe still run the strings for some pole beans.OK I am out want to get the field tilled one more time should be dry enough. Later guys
Now that is some hot coffee74 degrees, sunny morning to start this no normal day.
Good morning mopar misfits
Good Morning!!!
I'm thinking of starting a Go Fund Me site.
The purpose will be to raise gas and expense money for Karl to travel the short distance to Chris's for a couple days and put an end to they Poly madness.
There are emergency situations....
It really seems short to me, you get up to like 50 this baby is shaking like crazy....
What did you have it made for? Do you remember what length you had it made too?
