straightlinespeed
Sometimes I pretend to be normal
I would redo my 30's, maybe my late 20's.I would go back in a heartbeat. I would do some things different for sure.
Cinnamon vodka. Interesting.View attachment 1715502648 They have a wide variety of infused adult beverages.
The unpolluted variety is tasty too.
Napa is 5 cents cheaper. LOLNapa's Gold filter is a Wix filter. You could check there if they have one for your rider.
Our grass is just starting to turn green. I figure I have about 1 month before I have to mow yet. I did put my snow blower away and got the push mower in the garage this past weekend. The rider is still in the shed, that will get serviced soon.
As said, I had air pressure holding with no water coming out. In your tank, you have an outlet near the bottom. In a horizontal that outlet is midway on the side. If bladder is working, it's going side to side, not up and down working with gravity. If it is busted, then the tank is just open inside. So I would be very limited on the air space above the gravity drain line, where you have more like 95% that can drain and fill with air... I will try what you said and pump the pressure up. Also want to do some tapping and verify where the water is at.And it does not matter what size or shape the tank is (a tank is a tank and your water and air will take shape to the shape of the tank and air is lighter than the water) it has a top and the air even if pumped from the side will be at the top. I know you know all the principles of displacement even better than me. But it helps me explain what is going on. If your pump keeps running and you have no to little pressure your tank is water logged. Now you need to find out why.
mowed for the first time this spring on FridayNapa's Gold filter is a Wix filter. You could check there if they have one for your rider.
Yup. Complete kit. Never run. 80 ccMotorized bicycle?
I like CinnamonI cant touch anything cinnamon flavored anymore, makes me start to gag just thinking of it.. Ohhh how I abused myself in my 20's
Yup, I've mowed twice already...Needs it again in a few days.......Too much seed and fertilizer, I guess.....mowed for the first time this spring on Friday
And Keefer you will probably have to adjust your nut again
Trust me on this...I have installed a few and have been down your road
Again the Woopie Cushion you can keep putting water or air into it but it is the outside pressure (air) that makes it blow...
Ok, you got me there! I like that..
i have to re-seed the dog pen, my wife babysitting those dogs from my father in law destroyed my fenced in yardYup, I've mowed twice already...Needs it again in a few days.......Too much seed and fertilizer, I guess.....![]()
62* sat in my daughters yard and saw my granddaughters 4 and 11 months. Couldn't get near them yet, but nice to sit and talk rather than facetime with them. Told the 4 year old we had a cold so she couldn't hug, or sit with us. Man this sucks.
I miss my grandkids also. Son in law drove his Dart over the and the kids stayed in car. Quarantined in a Dart
