Stop in for a cup of coffee
I cant see why two wouldnt fit,as long as one was right tight out of the way. Set of dollies and a padded wall.
When i had my firebird i turned it
And put it against the end wall in a 20x32 garage. That was no fun. But my power wagon fit.
Thanks guys......Sorry if I was a little short.......Did not mean to be.....
I always thought you were kinda Tall??? BTW my lift bay is 14 ft wide, and as you know it is lower than the rest of the shop. Just the way the land rolls downhill here. My posts are 18 in from the wall on each side. But I made it that way on purpose so I would have more room on the upper level. I squeeze past the posts with no problem, often carrying something. Have pulled axles with no problems here.....
Pain in the butt moving my shop crane around, pulling engines is not easy. No room to back up and away without several s-turns. One thing about the 4 post compared to 2. Rolling stuff around.
Space I made
I am going to resign myself to centering the lift and putting the second car some place else.......Where I built it to begin with......Ratts!!!!
Been running in and out moving the sprinkler around the yard. Been dry for 2 weeks now.
The grass I don't care about much, it will come back...but the recently planted trees and landscaping cost me too much investment in time and money to let wither.
Damn, still no Coors Extra Gold being stocked. Just called my distributor and nope, none on the truck today. Try again next week.
Sigh. Only 2 cases left in my stash.
I bought a case of Michelob original lager and a case of Coors banquet last week just to have. I used to drink Michelob as my regular so it will probably be just fine. I’ve not had the Coors Banquet in a loooong time so it will be kind of a new discovery of sorts.
Enjoying the cold CEG tonight while watching the sprinkler do it’s thing.
Hey guys. Laying out my lift. 2 post. Does it REALLY need 3 feet between the post and the wall? AND 13 feet to back wall? Seems excessive to me........the posts are 132 inches apart! To the outside flange........That leaves A LOT of room in the center, cannot think doors will extend 3 feet outside the posts......
Yes!! We put ours exactly 3 feet and I wish we’d one 4-5.
I ended up putting it where Mitch said....we will see.....the concrete was only 3 inches thick. Some of it was put down a long time ago.....So I am cutting out a 4 feet by 4 feet section under each post, will dig it out to 6 inches and add rebar. Will be great.....
