Stop in for a cup of coffee
Buy it, put it on a stand and slowly restore it. Push it to the corner of your shop when your not working on it. Maybe one day you'll find a buyer for it. And he'll appreciate the attention to detail you put into it over the years.
I need it right now actually. Hoppy!!!
Old gall looked good back in her day, stained aluminum factory color.
I will be removing it all and polish her one side at a time.
I was considering that 383 because its ready to run. The 440s I've found are in ok shape but I figure if I went with a 440 I might as well just pull my 360 and have it rebuilt.
With that being said if I pulled the 360 what would be the best thing I could have done to it? Port and polish the heads and higher compression pistons, right?
Morning All, as its been stated, unless you're looking at just a "refresh" once you get into replacing parts, block machining, and balancing...you're on the doorstep of a crate engine with a 30 month warranty, that comes dyno tested. For your consideration. Chrysler Compatible Crate Engines
1st snag, the lower steering shaft has to come out,as u-joints are siezed. So is the telescoping part. I may have to pull column to get it out.
That little 3 1/4" X 4" SBF could make some little Falcon real happy :steering:
I have beer bottles soaking in suds. If the beer is ready i'll do some bottling in a hour or so. I have 4 gallons of Sticky Wicket Oatmeal Stout to bottle. It should be good to drink around Christmas.
Morning cousin! We are pouring the pad for new shop up in Prairie Grove next week. Pad is 50 by 95. Shop is only 40 by 80 but that gives me a no snake zone apron and a place to create a patio someday. Snakes get on the apron the Hawks will pick em off for sure. I have a used pool table found already. All I need now is a beer fridge with some go fast stickers on it!
Sounds like you got it going! Now I will have 2 brothers to visit when I travel south.
So the stickers make it chill the beer faster? Cool! :thumbsup:
