Stop in for a cup of coffee
It's Sharkmobile Saturday!
Good morning :D
We got the pop on the lift side noticed the temp and fuel gauge are not working and I just sold the last NOS current limiter I had!:rofl:
Good morning men.....Keith, that solid state flasher flashes even with one bulb, the same speed...Makes troubleshooting turn lights easier...IMO. It will flash with just the dash indicators...
I jump them to keep the lights on steady on that side usually
That's what I did and after messing with everything, they started working. Thing was, even when not working, I checked continuity from flasher connector through the switch and the switch seemed fine left or right. So even if it had some resistance or a bad bulb, it should have worked. Just would not have flashed at the right speed. After I got it working with flasher jumped, I had it working perfect with one of the old flashers I had. I did prove the other one I tried is junk.
