Stop in for a cup of coffee
Did you replace the ignition switch and wiring? Blue IGN wire is usually the culprit if old. All my blue wire does now is trigger a relay.
It is the original. I will put in a relay.....The blue goes to IGN box, as well as the regulator.
Get a Relay with 2 power outs. 1 to ignition box, 1 to regulator. Trigger the relay with the IGN Blue wire. Then you should be good to go. I would guess that there is voltage drop caused by your old Blue wire. It certainly has enough to trigger a relay though.
So mom happened to find this picture of me at age 6... with my dad and a German MG42 . How many 6 year olds get to shoot an MG42!
Having to modify wiring in dart to fix charging issue. No big deal, just have to unwrap a bunch of wiring I just placed. O well....
Hit the swap meet at the show, picked these up have $60 in all of it. The signs hung inside the dealership.
