Unconventional
Frosty roofs abound, down to 36 this morning. I was too asleep to hear if the vineyards were getting blow jobs
Little hydraulic lock thing goin on thereLever moves. Diaphragm not. Without taking it apart seems the spray nozzle is plugged...
Check the plunger in the squirter. I have had some of the diaphragms harden from the alcohol in the gas.Lever moves. Diaphragm not. Without taking it apart seems the spray nozzle is plugged...
Cooking Lard.In English?
I thought it said sticky gray goop.Cooking Lard.
It's going with the car.Try to get the cowl from him... Ol' Bob was whining about how he promised it to him and he hasn't gotten back yet....![]()
Benadril.Make sure they wear off in four hours or you will be hitting that "help I cant get down" button!
That is where they all go to......
Which carb Tim?Double checked carb. No pump lever movement. So remove carb. Sitting on bench works perfect. No obstructions installed so WTH
Putting it back on...it worked perfect till last night.....
All back together. Ran it on stands. Shifted perfect. OD works perfect. Getting somewhere
are you waiting for?
Brand new 770 Holley Street avenger.Which carb Tim?
Till the rubber meets the road.All back together. Ran it on stands. Shifted perfect. OD works perfect. Getting somewhere
What could possible go wrong. Sorry Tim just messing with ya. I hope it all works out.
Got another package today for the annual Carlisle run. A carb for Wolfe..
