- Joined
- Mar 17, 2018
- Messages
- 17,163
- Reaction score
- 41,938
I moved my coat from the left handle bar to the right on my exercise bike today. Does that count?Hey Mitch!
Did 30 miles on the bike this morning. New high mileage mark
I live in the desert, I needed it do dissipate heat good, and white was out of the question![]()
I'm very happy to hear that affirmative action occurs within your engine bay
EnjoyGooooood Mornin from Viet Nam. Headed up to Saigon again for the day...
Only if you move it back.I moved my coat from the left handle bar to the right on my exercise bike today. Does that count?
Yes. for the switched power side. The control side needs to be ran off the ignition feed. Maybe off the plus side of the coil. If you dont know how to wire a relay post here.....You might get away with wiring it to the positive side of the coil. But I would not leave it that way...just to get it running....
could I just run a wire off the solenoid?Yes. for the switched power side. The control side needs to be ran off the ignition feed. Maybe off the plus side of the coil. If you dont know how to wire a relay post here.....
There is no terminal on the solenoid that does that....the main term is hot all the time not switched.....could I just run a wire off the solenoid?
constant 12v when key is in run?
ok......There is no terminal on the solenoid that does that....the main term is hot all the time not switched.....
It’s a Pontiac, Right?Black Bays Matter![]()
So yesterday at work I was driving to the site, temp was 34 degrees and I was climbing so usually gets colder but there was a temp inversion and I ended up at 41 degrees at the site. I felt good about that then a co-worker returned a call, I hadn't heard from him in a couple days. He's in Cancun, 80 degrees, 5th floor of hotel looking over the ocean with Margarita in hand, damn!
Well don't talk to Mitch....![]()
Mopar didn't use very good quality steel.Dodge nitro in shop. Axle seal and transmission pan rusted through.
