And you guys are trying to convince us to move there. Not helping your case much....just sayinJust got to work a bit early. Roads were mostly OK. Rain had stopped for long enough to drain pretty good. Now drizzling again. Getting some icy spots…
Not that kit, but same style. Its all you need.Pulley Remover and Installer Set 12 Pc. (harborfreight.com)
Anybody used this kit? Now that we have HF in town may look into this as don't expect to use too many times.
Well sure, just slide on over…And you guys are trying to convince us to move there. Not helping your case much....just sayin
My good friend Ray.....No stay there! Or get a Trum Tatoo!
HmmGPS for lunch?
The remote waiters. Like a kiosk.What is that thing?
It’s a the brain wave signaling device that keeps all them lefties in lineWhat is that thing?
It's probably leaking out of the HVAC box drain.My Wife and Mom took my car in for a heater core change Tuesday. Dealership called and cant find a leak. Told them if you go anywhere past mid temp towards hot on hvac controls you smell coolant inside the car and you lose coolant from the radiator. They are still trying to find the leak. Will call me back on Monday.
At least the carpet is dry.
Might have to invest in one of these!
Element Extinguishers & Accessories – Element Fire Extinguishers
Does the shaft have a threaded hole in center?
Sorry, I was thinking the tire anti-freeze they sell here. They call it Anti-freeze. But in actuality it’s the exact same **** they spray on the roads. If you read the fine print on the sales receipt it states that it’s not to be used long term due to its corrosiveness
