What is that last measurement? Difference in length?
Yes. About a 1/4 inch.
Well, they were for sure on my 66 dart, so they are not to long....Old ones might be shorter, but they will fit, the new ones...New ones too long?!
T bars do not bottom out in the control arms......New ones too long?!
I'll have to see how it sits in the Suspension anchor and whether the locking ring will fit properlyNew ones too long?!
That’s kind of what I was wondering, I LS bet they’d be okT bars do not bottom out in the control arms......
Dont forget to grease them...I put a set from Mitch's Dart in the 66. They are all the same....I'll have to see how it sits in the Suspension anchor and whether the locking ring will fit properly
But I don't expect any issues
Evening, wind is still rocking 30-40mph with 60 mph gusts.
And grease the height adjusting bolt...Yes. I have new boots, clips and grease ready to go
Lots of grease
How about anti-sneeze?And grease the height adjusting bolt...
I was thinking locktiteAnd grease the height adjusting bolt...
OMG dont confuse the guy!!! Yes, anti seize is good as well, but I have had good luck with Red grease....I was thinking locktite
How I install, Put the new grease boot on the T bar, Slide in from the front, then install the lower control arm, bolt it in place, leaving the nut kind of loose, slide forward the t bar, put in the rear clip, slide the boot in place, then install the rest of the front suspension, leaving no tension on the T Bar, till all completed. then tighten up the adjusting bolt. that is how I do it...And of course grease both ends.....After the fight to get it out a definitely making sure the next (if there is one) is easy
You know I was being sarcastic right?Red or Blue??
I'm just slightly ahead of the guy looking for a spool of.flight line ...
And ...well... Google
Or assemble everything and slide the T bar in from the back....works either way...Dont tighten the lower control arm nut till it is adjusted for height. Then tighten it,,,How I install, Put the new grease boot on the T bar, Slide in from the front, then install the lower control arm, bolt it in place, leaving the nut kind of loose, slide forward the t bar, put in the rear clip, slide the boot in place, then install the rest of the front suspension, leaving no tension on the T Bar, till all completed. then tighten up the adjusting bolt. that is how I do it...
I do it with the weight of the car on the tires...How I install, Put the new grease boot on the T bar, Slide in from the front, then install the lower control arm, bolt it in place, leaving the nut kind of loose, slide forward the t bar, put in the rear clip, slide the boot in place, then install the rest of the front suspension, leaving no tension on the T Bar, till all completed. then tighten up the adjusting bolt. that is how I do it...
