No, the 68 - 69 air cleaners are smaller diameter than the 70 and up 340 air cleaners...
I'm just a bit of a dunce so bear with me... none of them have a model year noted ... so how do I know?.
What gear and trans you gotMade it home safely. Rained for the last 90 min or so. Great drive otherwise. 12 mpg for a cammed tunnel ram 440 with 660s. Is pretty damn good
Amber alert. Someone stole a Suzuki XL7 from local Royal Farms with a 2 year old in the back.Our shower stall downstairs has taller panels and shower goes through, but the tub surrounds aren’t tall enough. They recommend min 72. That would be right below the edge of the panel. The new Rain heads want mor like 80”. Our new one has a handheld inside a larger stationery one. I have it coming out at 76”. That’s about 2” higher than original.OOO I see it......![]()
I have a spot for you if you want to camp out.I plan to do just that
Those are all nice!!!Made her laugh..., here you go. And a good one Tim took
no green drywall??Our shower stall downstairs has taller panels and shower goes through, but the tub surrounds aren’t tall enough. They recommend min 72. That would be right below the edge of the panel. The new Rain heads want mor like 80”. Our new one has a handheld inside a larger stationery one. I have it coming out at 76”. That’s about 2” higher than original.
Mike. I was Told to tell you if you need your trunk dusted off again they are available.Those are all nice!!!
Friday night a jeep with a 62 old woman with dimentia was taken from a convenience store. Havent heard if she was found..F’n idiots!Amber alert. Someone stole a Suzuki XL7 from local Royal Farms with a 2 year old and in the back.
I had the cutest pair of butt prints on my trunk lid.Mike. I was Told to tell you if you need your trunk dusted off again they are available.
Is that the water resistant stuff? Never had it before... There was a little water damage right at the bottom. Thought about using it there. Could still change it I guess. Once you coat it with latex paint, and caulk the edges, it's waterproof...no green drywall??
is there special compound to use with that?no green drywall??
Yep water proof. pain to sand....is there special compound to use with that?
enjoyMorning folks
Taking a couple of days off work this week. Big effort wrapped up on Friday so it's a good time to kick back.
Be safe out there
