Stop in for a cup of coffee
Got more completed...
What parts did you replace with new?
The only thing from the front end are the upper control arms and the center link.
Everything else is replaced
PST front end kit
Classic disc brake conversion.
Replaced:
K- frame
Struts
LCA
Torsion bars
Steering gear
PST front end kit
Replaced:
K- frame
Struts
LCA
Torsion bars
Steering gear
and the new parts were for a valiant? I did not know there was a difference from a dart....
Original Performance Super Front End Kit
Classic Disc Brake conversion kit
1960-76 Plymouth Complete Front Disc Kit Booster Combo
Current Brake Type: Currently Manual Brakes
Original Engine Type: 6 Cylinder
Transmission Type: Automatic Transmission
Brake Type When Complete: Disc Drum
Front Chrome: Plain
Year: 64
Wheel Size: I'll be using 14" Wheels (+$300.00)
Front Chrome: Plain
Year: 64
hmmm
I fiddled with cruise control in the fargo, there is an air filter on it. Was turning to dust. Added a ground to it. Tested switches repeatedly. No glitches. then figured i would sort out the bouncy speedo. Cable doesent match the speedo. Changed speedo. Added another power point and relocated the rotary fan switch. Then a birthday party.
tomorrow reseal windshield and add weatherstripping.
looks like maybe the center section is backwards?
I've been reading the tech manual over an over to figure out if there is a "front" and "back" or "left" and "right" nothing to indicate that there is. Images are not the best... I've pulled several off the web but they lack any real detail
There seems to be a fairly high occurrence of oddities with the car.
I'll compare this tomorrow.
end for end it......
